How to configure Maestro for straight key operation?
James Charlton
Hi,
I seem to have **** up my new Maestro as far as using a straight key is concerned. I had a paddle connected and it worked fine with the keyer.
Now I am trying to use a straight key, but the keyer comes on and sends dots as long as the straight key is pressed.
I am using the Maestro with a 6600M. The 6600M operates as expected with a straight key (i.e. no keyer) as well as operating properly with a paddle and its keyer enabled.
I believe have configured the maestro the same as the 6600M as outlined below, but it still insists on using the keyer.
configuration
V2.3.9 or V2.4.9 both behave the same
Maestro (Keyer operates even with a straight key plugged in)
Phone/CW menu
Iambic: Disabled but "B" is highlighted
Breakin: Enabled
Swap: dark
CWX: Sync
6600M (Keyer does not operate with the same straight key as above)
All settings the same as above but enabling Iambic enables paddle operation
Can anyone tell me how to get the straight key to work on the Maestro?
Thanks in advance,
Jim Charlton AD0AB
configuration
Phone/CW menu
Breakin: Enabled
Swap: dark
CWX: Sync
Thanks in advance,
Jim Charlton AD0AB
Page 16 of the manual... you do not use the pin out as a paddle0
Jim,
I think there is a typo in the manual, I connected my straight key to the tip and sleeve per the manual with the same results. I believe it should be connected between ring and sleeve. I found that if I used the following it works fine.
Swap: highlighted
Brian/W8WD
Thank you! I checked the manual and my key is wired as shown.
Regards, Jaimie AD0AB
Brian,
Thank you! It turns out my key is wired according to the manual (tip and sleeve, no ring connection) but, "Swapping" solved the problem.
This means that the Maestro and the 6600M are not set up the same internally. It doesn't matter as long as I know the fix.
Regards,
Jaimie AD0AB
I think this is a clear issue that Flex should comment on.
I would like to know why Tim is not commenting on the community any longer.
Jeff0
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 192 SmartSDR for Maestro and M models
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 983 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
