Proble playing back recording when Transmitting. Started with 2.4.9 update. I used to be able to hea
Brooksie6444
I do not hear the off air recording when transmitting. Used to work with the previous version. Went back to the old version and it works like it should. Using Flex 6400M.
I will try here,,,0
I do not hear any playback at all.0
It is working as it should, I hear my recording when pressing the play button. To play over the air you press the DAX button as well.0
SAME HEAR ,i use to be able to hear , not now
Jim
WU5E0 -
I never had to push DAX to hear my playback over the air. I would just push play and PTT and I could hear it as it played over the air.t
MONitor enabled?0
This is a change made to dax, you need to use it to play over the air now.0
Not working correctly here. Switched bands and voice recorded usually carries over to any band switched to and this looses it and wont replay when bands are switched.
Also have to have just the DAX button lit up on the main panel not actually have separate Dax panel on to hear the play back which is changed I guess. Doesn't make sense to me.
Nothing was wrong with it in the first place so why the change?
6.40.80.160 meters works but needs dax main panel button on to hear and play over the air. So not all bands working the same looks like.
Mine works with or without DAX. Seems to be working normal.
And I have no use to play back after switching bands and don't remember trying it.
I do a recorded CQ and switch bands and re-use the CQ.1 -
Not seeing this in the change log unless I missed it which is possible.
Makes sense.
I don't know, they did make changes so DAX is used with Smart LInk now. That may have effected what we are seeing with simple record and playback over the air?0
Clean registry install and all is working with DAX-main panel (blue-on) to hear playback and transmit.
The other separate dax panel is not turned on .
All bands working correctly.
If I make a recording and turn vox on and press play it will transmit the recording over the air. With Vox on every time I turn Dax on the radio disconnects.0
- 352 Community Topics
- 615 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 412 SmartSDR for Mac
- 267 SmartSDR for iOS
- 250 SmartSDR CAT
- 187 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 22 Aurora
- 211 FLEX-8000 Signature Series
- 922 Maestro
- 894 Genius Products
- 323 Tuner Genius XL
- 116 Antenna Genius
- 284 Shack Infrastructure
- 200 Networking
- 138 Contesting
- 974 Third-Party Software
