Proble playing back recording when Transmitting. Started with 2.4.9 update. I used to be able to hea
Brooksie6444
Brooksie6444 Member ✭✭
I do not hear the off air recording when transmitting. Used to work with the previous version. Went back to the old version and it works like it should. Using Flex 6400M.
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    edited September 2018
    I will try here,,,
  • Bill -VA3WTB
    I do not hear any playback at all.
  • Bill -VA3WTB
    It is working as it should, I hear my recording when pressing the play button. To play over the air you press the DAX button as well.
  • James Kennedy-WU5E
    James Kennedy-WU5E Member ✭✭✭
    edited June 2020
    SAME HEAR ,i use to be able to hear , not now
    Jim
    WU5E
  • Brooksie6444
    I never had to push DAX to hear my playback over the air. I would just push play and PTT and I could hear it as it played over the air.t
  • W7NGA
    W7NGA Member ✭✭✭
    MONitor enabled?
  • Bill -VA3WTB
    This is a change made to dax, you need to use it to play over the air now.
  • AA0KM
    AA0KM Member ✭✭
    Not working correctly here. Switched bands and voice recorded usually carries over to any band switched to and this looses it and wont replay when bands are switched.
    Also have to have just the DAX button lit up on the main panel not actually have separate Dax panel on to hear the play back which is changed I guess. Doesn't make sense to me.
    Nothing was wrong with it in the first place so why the change?
    6.40.80.160 meters works but needs dax main panel button on to hear and play over the air. So not all bands working the same looks like.
  • Rich McCabe
    Rich McCabe Member ✭✭✭
    Mine works with or without DAX. Seems to be working normal.
    And I have no use to play back after switching bands and don't remember trying it.
  • AA0KM
    AA0KM Member ✭✭
    I do a recorded CQ and switch bands and re-use the CQ. :)
  • AA0KM
    AA0KM Member ✭✭
    Not seeing this in the change log unless I missed it which is possible.
  • Rich McCabe
    Makes sense.
  • Bill -VA3WTB
    I don't know, they did make changes so DAX is used with Smart LInk now. That may have effected what we are seeing with simple record and playback over the air?
  • AA0KM
    AA0KM Member ✭✭
    Clean registry install and all is working with DAX-main panel (blue-on) to hear playback and transmit.
    The other separate dax panel is not turned on .
    All bands working correctly.
  • Bill -VA3WTB
    If I make a recording and turn vox on and press play it will transmit the recording over the air. With Vox on every time I turn Dax on the radio disconnects.
