I lose comm with Antenna Genius during transmission
W2PP
Member ✭✭✭
I have the 8x2 antenna Genius mounted on the tower in a NEMA enclosure. When I transmit with 100 watts all is fine. When I transmit even with as little as 600 watts the AG comm is lost.
I fear this is near field effect, but, is it on the AG itself or is RF getting in the Cat6 cable?
Just wondering if anyone else has mounted the AG at the tower and what the result was. Should this be insurmountable I did leave my DXE switch wired and in place.
Peter
Peter
Can you try wrapping each end of the CAT6 cable around a mix 31 ferrite?
Sounds like RF getting into the network.
Is the cable shielded? Do you have each end grounded if it is shielded or only one end?
Having just had a bad lan cable issue, I would do what Dave said. I would also try changing or swapping Lan cables That should solve your problem0
4o3a got back and feels it’s RF on the LAN so I’ll try some ferrite beads since I happen to have those first. The CAT6 is shielded but NIT grounded I’ll take care of that. I’m also going to put sone ferrite beads on the power cable all of course at the AG Thanks guys Peter0
- 390 Community Topics
- 662 The Flea Market
- 440 SmartSDR for Mac
- 55 Aurora
- 971 Maestro
- 946 Genius Products
- 308 Shack Infrastructure
- 216 Networking
