N1MM using with Maestro Remote
Laurens PD9X
Is it possible to work with N1MM and Maestro while using Remote smartlink to a Flex6400 without using an extra computer on transceiver side?
No0
Yes, you can use N1MM remotely if you load SmartSDR on the PC that is running N1MM at your remote location. SmartCAT can log directly into the radio over the SmartLink connection without a PC at the radio end.3
Tnx for replying. But if I am connected with smartsdr, it is not possible to use the Maestro. I want to use Maestro and N1MM remotely over internet0
You can use a Router to Router VPN link to allow the radio and N1MM to communicate. That way you will not need a PC at the Remote/Radio end.
Can't you use SmartCAT at the same time as the Maestro?0
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
