N1MM using with Maestro Remote
Laurens PD9X
Laurens PD9X Member ✭✭
Is it possible to work with N1MM and Maestro while using Remote smartlink to a Flex6400 without using an extra computer on transceiver side?
  • Steven WA8Y
    Steven WA8Y Member ✭✭
    edited September 2018
    No
  • Gerald-K5SDR
    Gerald-K5SDR FlexRadio Employee ✭✭
    edited April 2019
    Yes, you can use N1MM remotely if you load SmartSDR on the PC that is running N1MM at your remote location.  SmartCAT can log directly into the radio over the SmartLink connection without a PC at the radio end.
  • Laurens PD9X
    Tnx for replying. But if I am connected with smartsdr, it is not possible to use the Maestro. I want to use Maestro and N1MM remotely over internet
  • K1UO Larry
    K1UO Larry Member ✭✭✭
    You can use a Router to Router VPN link to allow the radio and N1MM to communicate.  That way you will not need a PC at the Remote/Radio end.
  • Adde Tjernberg
    Adde Tjernberg Member ✭✭
    Can't you use SmartCAT at the same time as the Maestro?
