Using DAX Audio RX1
W5AP
Although my DAX control Panel v2.3.9 shows Slice A Streaming, I'm unable to input the audio to any program such as MMTTY, MixW, or FLDIGI
I get an error message "The sound card you have chosen (DAX Audio RX 1 (FlexRadio System is already in use or does not exist or does not support wave format. The sound card operation is disabled"
How can I fix this? Is this the result of something Windows changed? Used to work fine
Probably you have issue with DAX drivers in your system after update, check Device Manager and your Audio with View selection - Show hidden device
In case many double/hidden entries in the Device Manager, you should delete unnecessary and in case necessity reinstall DAX drivers as described here https://helpdesk.flexradio.com/hc/en-us/articles/204017069-How-to-Manually-Re-Install-DAX-Drivers0
- 653 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
