Auto Bandswitching Module for ICOM IC-2KL, IC-4kl and PW1 Amplifiers
I have a 2KL with the 10 meter option installed so whats the story now?0
Burt,
What is your amateur call? The same applies to the 2kl as the 4kl except the connector to interface with is a cinch jones type connector instead of a din connector if I remember correctly. You need 8v, the band voltage for 10 meters and ground going to that accessory connector.
Ed W2PH0 -
You also need 13vdc to enable the amplifier to turn on to the same accessory connector0
K1OIK, so I need 8v, band voltage and 13v correct?0
Yes, that should get you on 10 meters0
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 95 Aurora
- 988 Maestro
- 963 Genius Products
- 353 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
