6600(m) cw mode memory buffer
Rej va2am
Rej va2am Member
edited April 2020 in FLEX-6000 Signature Series
6600(M) stand alone, can we store short cw messages like Call 599 report for dx?
or do we need to install a third party software?
Thank you
  • Rich McCabe
    Rich McCabe Member ✭✭✭
    edited March 2018
    There is a CW memory function key that you can program (F1-F6). So I would assume you could program 6 memories if you used all the Function keys.
  • Reggie-k6xr
    Reggie-k6xr Member ✭✭
    edited April 2020
    F1-F6 store functions like Vox on or off etc etc. I cannot find any cwx or cw memories. I use FRStack which does provide that for the 6400M. I suppose it is the same for the 6600M? Unless I am missing it!
  • Rich McCabe
    edited March 2018
    "SEND CW" Third from bottom on mine.
  • Reggie-k6xr
    edited April 2020
  • Reggie-k6xr
    edited March 2018
    Rich-- third of bottom where? I have the 6400M and cannot find a place to store cw memories?
  • Rich McCabe
    edited March 2018
  • Duane_AC5AA
    Duane_AC5AA Member ✭✭✭
    edited May 2018
    I take it CWX doesn't work when the rig is run with the Maestro.  If it's needed, maybe you can run the rig from a PC SmartSDR when you need CW buffers.
  • Reggie-k6xr
    edited March 2018
    Ill have to see how that works! I have other things programmed there at the moment. Never thought of CW!!  thanks
  • Reggie-k6xr
    edited March 2018
    figured it out! works...
  • Rich McCabe
    edited March 2018
    It does not. If Flex ever implements mulit-client where you can use knobs and SSDR at the same time then it should but currently its either or.
    Rich
  • Geoff_W8GNM
    Geoff_W8GNM Member ✭✭
    edited August 2018
    Is there a way to halt the CW memory transmission before it completes?
  • Duane_AC5AA
    edited August 2018
    I assume you're talking about CWX.  If so, hit the ESC key.  Stops it immediately.
    (Edit) - oops, looks like we're talking Maestro - missed that.
  • Geoff_W8GNM
    edited August 2018
    Hi Duane,  Thanks for the reply.  I am using the front panel function keys to send CW macros from the front panel of a 6600M.  I am wondering if there is a way to terminate a transmission part way through the message from the front panel.  Thanks, Geoff
  • Duane_AC5AA
    edited August 2018
    Yep - sorry Geoff - I missed the context when I posted.  Since I don't use a Maestro or an "M", I'm only familiar with CWX.  Someone here will have an answer for you, I'm sure!
