Strange RX behaviour on slice 1 only my Flex-6400
Jeff | VA2SS
Hi to all, I am a new user and owner since last May of a FLEX-6400 and Maestro. I having a strange behaviour here with my Flex-6400... seems to be on 20m only. On 20m band slice 1, I have a strong AM broadcast station just below 20m that seems to have some bad side effects on my reception. But if I turn on slice 2, I cannot reproduce or even see the same strange behaviour. My question is, should I see the same strange reception behaviour on both slices ??? See picture...
Thanks for your help. 73 de Jeff | VA2SS
Thanks for your help. 73 de Jeff | VA2SS 0
do you have the Pre-AMP on, Pre-AMP's on the lower HF bands actually make things worse and cause overload AND are NOT required at all and shouldn't be used.
Just something simple to look at.
73's
Bret
WX7Y
Are you using the same settings, receive bandwidths, same antenna, same pre-amp levels etc.
I a have issues with 5th harmonic here with an AM station across the street about 700 feet or so across the street, and see same on both receivers if there set the same they look identical0 -
Yes, I’m know. But even with the RF gain set at -8dB.... still have the same issue on slice 1 only. 73 de Jeff | VA2SS0
Yes, both are identical.... as far as I can check my settings.0
I found the culprit setting..... If I activate WNB.... even at the lowest value, the behaviour starts.... I can reproduce on both time slots.0
Now, even with the RF gain set at maximum, this strange behaviour canot be reproduce. So this is related when using WNB, even at the lowest value.0
So, WNB for on 20m seems to be useless for me. Anybody else could try the same RF test ??0
WNB works great on 20m on my 6400. But, you need wide band noise for it to do anything. There are some good posts on this in the community.0
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 966 Maestro
- 938 Genius Products
