SSDR IOS via ipad 5 (2017)dropping connection
Vin Jacobo
I have been using the 2017 ipad with ssdr ios and flex 6500 for about a month now operating exclusively in cw. It is really a pleasure but ocassionally in the middle of a qso, while sending or receiving, the connection between the radio and ipad drops. The software quits and goes to the ipad home screen. I can usually resume the qso by restarting the app, and it goes right back to the same frequency but I usually miss a few words or If I am sending it does get a little embarrassing. This is ios 11. Flex 6500. I am running a strong mesh network which provides speeds of 170mbps down and 36mbps up verified at the ipad. The Rig is hardwired via cat 6 cable. The ipad is set for a fast network and to prevent sleep mode. Any ideas on what could be causing this?
(PS- I run ssdr on windows via the same wifi network and have never experienced any disconnects even when the PC is at the same location as the ipad).
Tks
Vin
wz2j
Tks
Vin
wz2j
ok bob ! im same app but 6700 and 6300 and some times (not often) get the same thing the screen slows (waterfall) then stops audio carries on! but a reboot of the app gets you back.. a little annoying oh and i am on an IPad 6 (16gb) Windows works fine.
I would be very careful with the above post recommending iphonecustomersupportnumber web site. Looks very bogus to me and I would NOT click on the link.
If you need support on your iPad go to Apple's official web site https://www.apple.com/
Is your mesh network set up with multiple access points on different frequencies? Wondering if the iPad can be sampling other WiFi channels looking for stronger access points?
Is there something running in the background on the iPad causing interruption of the WiFi? Try a cold boot of the iPad by holding the Home and Power buttons until you see the Apple logo (ignore the "Slide to shut down" message.
My question is (and I am having the same problem in ssb) is where do you go for help for this software. I don't see any link to the author for help. Once buying the program it seems you are on your own for support.
You can post your questions here. Marcus (author) and other Community members can get you help quickly.
A good guide to answer common questions is available here
https://manuals.roskosch.de/smartsdr-ios/
For official support open a HelpDesk ticket
https://helpdesk.flexradio.com/hc/en-us/requests/new
There is support for the app officially through the HelpDesk but you may find your answer and get a quicker response by searching or posting on the Community.
Dave wo2x1 -
OK thanks Dave I have never seen the manual for this software, never knew it existed ! This would have been a great deal of help instead of me trying to figure everything out. I must of missed it if it was mentioned when I purchased the program. When I say manual I mean the manual for the Ipad APP.
- 379 Community Topics
- 120 SmartSDR+
- 193 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
