6600 front panel power switch shutdown delay
Geoff_W8GNM
Add two second delay to 6600 front panel power shutdown sequence?
I have accidentally shutdown my Flex 6600 by inadvertently touching the power switch in the upper left hand corner of the front panel. This can be very embarrassing while I have to wait 1:50 for the radio to restart. I often use the MOX button on the front panel when running nets instead of VOX or other PTT input devices. The location of the 6600 power switch is in the same quadrant of the front panel as the "Transmit" function on other rigs and could be confused with the transmit function. It can also easily be unintentionally bumped which shuts down the radio instantly. My suggestion would be to add a press and hold function to the power button for two seconds before the shutdown sequence starts.
2
good idea...even though it is big green button..sometimes muscle memory over takes rational response
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 192 SmartSDR for Maestro and M models
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 983 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
