Antlion ModMic 4.0 mic profile
Tim K9WX
Member ✭✭✭
Is anyone using an Antlion ModMic 4.0 with your Flex? Specifically a 6600? I know every voice is different, but if you are using this mic and would care to share your settings from your microphone profile, it could help me settle on the settings I will want to use.
Tim K9WX
Tim K9WX
Hi Tim:
It does not matter what mic you use, or whose voice is used with it, as long as you know how
to monitor/hear/record YOUR audio, so you can adjust it how it sounds good to you.
Even if someone else had answered that they have that same mic, their voice settings would
likely be wrong or "blah" for your specific voice.
Ken, one of the Elmers here, put together this great post below.
Since you have a model 6600 (has full duplex), you can use the same info;
https://community.flexradio.com/flexradio/topics/how-i-am-now-using-full-duplex-to-monitor-my-ssb-and-am-audio-adjustments
There is a link to his more recent video in the middle of the thread.
Since each person has a unique blend/balance of high and low frequency
speech patterns, this procedure will permit anyone to adjust any mic.
I can't recall if the thread mentions it, but you can all use a free Windows Audio Editing program called Audacity to select the DAX audio channel from the Flex, and record your voice while
transmitting, perhaps 1 watt into a tiny dummy load. Then you can play it back, and decide
what else to adjust.
I hope you find the info helpful, and Ken is great at answering additional questions.
Cheers,
Neal1 -
For others who might be interested in using this microphone, here's the wiring diagram:
Tim K9WX
Hi Tim
Are you saying there is an adapter cable needed to use the ModMic on a Flex?
73 Holger, ZL3IO-1 -
There are three audio tutorials on the YouTube page. Look at the one on monitoring yourself. Then listen to the tour of audio profiles. That will help you decide what kind of audio profile you want. Then do the one on how to adjust your system for a new mic. NOTE... these videos refer to saving your audio profile in the Transmit Profile. They are now saved as a Mic Profile. I hope they help. Please let me know if you need additional help.0
Hi Ken
I'm not sure if your reply was meant to answer my question as it didn't. I'm far away from the point of monitoring. I'm not able to create any audio out of the flex. It goes to transmit but no modulation of any kind. The ModMic's were used on the K3's here without any modification but some setting changes (bias voltage). Seeing the sketch from Tim it seems I need to solder an adapter cable.
I was hoping other users came across this before and had some hints what settings to use with ModMic.
73 Holger0 -
Hello Holger,
My post was a followup to Neal's response to the original post.
Yes, from the diagram it seems that you need to solder up an adapter cable.
The mic seems to connect the tip and ring together, as many computer mics do.
The Flex uses a pseudo-balanced arrangement where the tip is the positive side of the mic, the ring is the negative side of the mic, and the sleeve is the chassis shield. If you just plug it in as is, you will short your mic.
Good luck.
Ken - NM9P0 -
Thanks for reply, Ken. Made the adapter --> worked, followed the monitoring yourself instructions and all is fine now. Good reports via radio.
73 & thanks Holger0 -
I use a stereo to mono Adapter, works great
Great! Thanks to Tim K9WX, too, who provided the diagram.0
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
