iPad A10 Fusion Chip, 128GB WiFi only suitable platform for SmartSDR IOS?
Ronald Panetta
I am looking for an iPad for SmartSDR. I currently use SmartSDR on a Windows laptop and Maestro. I like the iPad form factor but am currently Android based. I notice Costco has the above unit on sale for $360 after a $40 savings.
I realize this unit is WiFi only and I have no need/desire for mobile data network use (I am aware of some strong opinions within the community recommending an iPad with mobile data).
So the question for the community, is this a reasonable platform for SmartSDR IOS? Will it give some suitable headroom for future SmartSDR growth? Are there any more cost effective options as a platform.
Thanks in advance!
73, Ron WB2WGH
Thanks in advance!
73, Ron WB2WGH
Any iPad capable of running iOS 10 will work. Anything being sold today will likely come with iOS 11. Should run SSDR for iOS just fine. I use a two year old iPad and it works great. I suggest buying a bluetooth headset with mic, and maybe a bluetooth Griffin Powermate (knob device with a single push-down function, used for tuning).0
Ipad MRJN2LL/A $329.00 works great. 2018 model
Terry
Ted, Love BT headsets and so does spouse! Yes, should work great on iPad. Will look into GPM as that sounds like a winner.
Terry, yes, saw the Ipad MRJN2LL/A. Only has 32GB and for the extra $30 I get 128GB with the Costco item. One can never have enough memory. Having said that, most of my apps are on the Android.
Ted & Terry: Sounds like both are winners with respect to SmartSDR IOS. Will move forward with one of them. Thanks again for the insight!
Ron0 -
Large memory iPads get you lots of storage space, but no increase in performance. Apple’s iPad selection tool shows that large memory units are for those that might be storing lots of photos or videos or editing videos. If your primary use is for SSDR for iOS, 32 gb will be more than sufficient. As for mobile data, skip it and use the hot spot feature on your Android phone for Internet access.0
I have a 2018 iPad with unlocked cellular currently with Verizon 4G LTE sim and unlimited data. Love it! I use it for quick remote access into a couple of aystems at work for diagnostics but also use it for a bunch of personal IOS apps including SmartSDR for IOS. I was just using it today when parked waiting for my wife to come out of the store. I have a Plantronics Voyager Bluetooth earpiece, Bose QC20 noise cancelling earbuds (Was using today), and a RadioSport RS55L traveller headset. All work well with good audio reports. If you plan to go remote with the iPad in areas that do not have WiFi then the cellular models work great. Typically they are about $10 a month more to add to your cell plan. Make sure you have an adequate data plan. Marcus has done wonderful things with the app and his support is top notch. Best $50 I spent in this hobby. Dave wo2x0
So it sounds like the 2018 iPad platform is the way to go. To Bill's point, if mobile connectivity required, i can do that via Android hot spot. That is my plan. No need for 2 data plans. Per Dave and Ted's posts, lots of Bluetooth options available. Also sounds like no issue cheaping out on the 32GB, save the $40 and credit it to the purchase of SmartSDR for IOS given my primary device for apps and music are my android. Will likely load a few other ham related apps as don't want to be juggling iPad and Android at the same time.
Ron, WB2WGH
You can add logging also, although like adding support for the Griffin knob, it will cost you a few dollars (the current price for options can be found in the app under tools. The cost depends on currency, but I think it's around $7 per "tool".0
Ted, yes logging is one of those "other" ham tools/apps i would want on the iPad.0
Done! Was at BJ's this AM. They have 32GB version MRJNFLL/A for $319.99 less $30 clipless coupon netting at $289.99. For those interested, clipless coupon expires 8/19. Bought it so now time to go play. Thanks all! Ron, WB2WGH0
- 378 Community Topics
- 116 SmartSDR+
- 923 Genius Products
