Flex 6300 Works on LAN but now not on WIFI
KZ6B
Member ✭
I had the 6300 working on LAN and WIFI months ago with no problem. Recently I used the 6300 on LAN no problem, but when I went to use it on WIFI I cannot get connected. I get as far as clicking the Test button but it turns up red. When hovering the cursor over the red Test button I get the following messages:
Forwarded Ports TCP=Fail UDP=Fail Hole punch supported: No.
Not sure what has changed as it was working fine.
Any suggestions would be appreciated. Alan KZ6B
Try turning off your radio and reboot your router. Then, turn on your radio and see if you are, then, recognized on Smartlink.
I'm not sure the problem has been described in enough detail.
When you are using it "on WiFi" are you talking about WiFi connected to your own router on the same LAN? If so, then you don't need to care about the state of SmartLink, it should connect directly on the same subnet in the same way as if you were wired to the same router.
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
