No Output
DonS
Member ✭✭✭
I was operational on August 2 when I worked several stations using FT8. Have not used the radio till today. Powered it up today and pressed the tune button in SSDR and no output. I put the radio in cw mode and keyed the radio. It is going into transmit and the pan display shows activity from the keying but no power out. When I run WSJT-X in FT8 mode and call a station I see the DAX TX Stream transmitting and the bar moving to the right and I have the gain set for 35. I see activity on the level meter but no output on the power meter nor the LP-100A. I am receiving plenty of FT8 signals. I have tested the radio on three or four bands using a dummy load and also a vertical and hex beam. Any thoughts and the pc has not gone through any upgrade that I am aware of over the past few days.
Don - kx9q
Don - kx9q
Make sure you have the right antenna selected for the slice you're using.0
Must have been pilot error. I just noticed XVTR was selected instead of ANT1. Not sure how that happened. Perhaps when I switched to 2m to see if I could hear anything but I do not have a XVTR.
Don - kx9q0 -
Don't feel bad Don. My suggestion was the result of my own bit of cockpit trouble.0
Hi Don, Yesterday I reassembled my station, and was having issues with getting no signal out. When I reset my autotuner, I accidentally put it on antenna 2. DOH! It happens, and you're back on the air, so it's all good.1
- 654 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 968 Maestro
- 940 Genius Products
