Flex 6300 with DAW and DAX
Dave
Good day all,
Has anyone managed to get a 6000 series Flex working with DAW Software. I use Voicemeter Banana and Audiomulch on my Anan 100. The problem I have is I cannot get DAX setup to work with the aforementioned software with Smartsdr and DAX
I don't even know if DAX will work. When we still used VAC Cable software it was not a problem.
So if there is anyone who has setup a DAW with an external sound box, like a UMC22 or Presonus Audiobox USB 96.
I would be really grateful to get the DAX setup so that the software, sound box and flex all communicate to each other
Kindest regards, Dave (ZS6AVM)
Hi David,
I have not tried this. I am not completely sure what it is that you are trying to do. Are you trying to route receive audio from Flex to your DAW? Or are you trying to send pre-recorded stuff from your DAW to your flex?
In my experience DAW programs allow you to record and playback usually multiple tracks of audio. Most of these are set to output stereo data. I believe if you want to send that to Flex you are going to end up losing either the left or right channel. If you send to the TX DAX audio device it will be mono data I believe. I could be wrong about this.
I will play around this weekend and see if I can get my DAW and flex talking. I never tried.0 -
Dave it should work, When i first got my 6400 I used the Focusrite 2i2 box and Ableton live to put that audio back into the flex 6400. However I stop using that as i found the newer EQ in the 6400 was better then the EQ I had when using the 3000. I had my output on my DAW going into VB-Cable which is also same company as your Voice Bananna. I set the software i the 6400 to use the PC. And then set VB cable as my recording device- I did not use DAX for incoming audio, only outgoing Used the second VB cable cable as a hand off from DAX and then set it to play back through the PC speakers which uses a set of studio monitors, and a Kinter digital AMP from the sound-card. I never cared much for the dreaded VAC program and found I had better results withe stability and throughput using VB cables instead when running the 3000. save your VAC key and give VB cables a try the first set is free the second set I donated 10.00 bucks for making it less cost then VAC as well. https://www.vb-audio.com/Cable/0
Many thanks Richard (great call for an SDR user)
All noted on using VB Cables, now we are getting somewhere
I am not sure with regards to the use of 2 VB Cables, is two VB Cable Software free. Perhaps I am going off on a tangent here. I seem to remember that one VB Cable was free with Banana and if you need a second one you need to make a donation. I will have a look again
Okay I see that he end of your comment that I was not disillusion with regards to 2 VB Cables, so will need to make a donation
Thanks for your response Richard, I will give it a go, as I really enjoy using a DAW for TX Audio. I do have a full hardware rack, but setting up audio with say Voxengo Overtone GEQ is much easier, less critical parameters to deal with
Kindest regards, Dave (ZS6AVM)0
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
