TX 1 2 3 not working
W2PP
Member ✭✭✭
OK just got the Flex 6700 back from fan repair...thanks for that...but TX1 2 3 are not keying my amp. They are enabled. What am I missing????
Peter
Peter
Guess you could Reset Radio. If that does not work
Downgrade to lower version try it out then upgrade to higher version
Which Amp are you using ?
73 Mike
( Use an Ameritron Buffer switch here between Flex and Amp here )
Are you running DDUTIL ?
If yes, that would be a good starting point to check as it enables/disables TX lines for different amps.
73, Andreas, N6NU
Not using any other programs. I can short the cable ends and the amp keys so it’s not the cable. The radio was reset nadda Peter0
And the TX outputs are enabled?
Yes they are0
Enable a profile and check.
If not enabled maybe add it to be ( on) in the profile and save.
They are enabled0
Do you have any global profiles in the drop down menu?
Might make create a new profile and add the Tx-1,2,3.
Not sure what (*default) entails.
These profiles will change as you change them on the main Ssdr software interface in the back ground.
I have tried multiple of my profiles0
The " * " indicates that changes have been made to the Default Profile, and haven't been saved.
For real-time discussions
User created documentation.
Volunteer!!73, Jay - NO5J
OK solved, what a ****....I used a picture of the rear of the 6700 off the internet that was WRONG. I had the PTT lines in the wrong places....man...once in the correct spots of course it worked. How embarrassing to say the least
Peter
Well, some progress but things are not right. Only TX1 toggles the amp. I've tried disabling all of them, and nothing happens, .....if I enable TX2, then TX1 toggles NOT TX2, ....enable TX1 and TX1 works just fine.....I can short the cables of course then things work fine....thoughts????
Peter0 -
Sounds like you need a factory reset..0
OK, how might I do that?
and thanks
Peter0 -
And, you don't need to refer to yourself as a ****, for making a simple human mistake.
[The only thing I hate more than perfect people, are the ones who THINK they are perfect! :-) ]
Cheers,
Neal0 -
I think Patton said something like that!0
Peter, hold the center button in on the multi button while also holding in the power button,,so both together...the front screen will count down to 0,,then release buttons..
The light on the power button will flash white when it is resetting.0 -
Tim and I have been emailing....looks like its hardware so home it goes....thanks all.0
- 379 Community Topics
- 631 The Flea Market
- 123 SmartSDR+
- 193 DAX
- 39 Aurora
- 948 Maestro
- 925 Genius Products
- 337 Tuner Genius XL
