Using DAX IQ for satellite telemetry query
Ross Biggar
I want to be able to use DAX IQ to record telemetry from various satellites. and the save the data to a .wav file.
My question is where is the data being saved, or else how do I save the downloaded data?
Advice please.
Ross
ZL1WN
Advice please.
Ross
ZL1WN
Ross, I think its only saved in memory of the Flex. To record it and use it or review it you would have to use one of the telemetry programs or something and audio recording software such as Audacity.
Use a third party program to record and select the appropriate Dax channel as the sound input
That will allow you to save it where ever you want and replay or send
NN9DD0 -
Thanks Lee, recording into Audacity worked perfectly.
Next I want to be able to output the file to a modem program which is running in the radio, what flexsetting should I use to get the output from Audacity .
Regards
Ross
Thats great news. In order to play the audio out of Audacity into the flex or you would select the dropdown box to the right of the speaker icon and use DAX Audio TX. That will send the audio to flex transmitter.
Is this what you are trying to accomplish ?
Lee
You can also record up to 192Khz with PowerSDR , running in Demo mode , DAXIQ as the audio input .0
Dudley does PowerSDR run on the Flex Signature Series ?
- 379 Community Topics
- 631 The Flea Market
- 123 SmartSDR+
- 193 DAX
- 39 Aurora
- 948 Maestro
- 925 Genius Products
- 337 Tuner Genius XL
