N1MM+ and 6600 2..3.9 SSDR CW
Dallas k1dw
Trying to get N1MM+ (latest version ) and SSDR (2.3.9) to work SO2R with 6600. The N1MM+ data entry window Keyboard commands do not shift the TX in the FLEX /.. ( ie Break , , ) is this a N1MM set up problem or a Flex connection problem, or both? The Break is used to shift the TX from band slice A and B. (ie one slice on 20 meters and the other on 40 meters. ) There does not seem to be any instructions on either N1MM or SSDR web site or on you tube. Can you offer a suggestion/
Hi Dallas, there could be some causes for it. First, have configured OTRSP settings in the N1MM meny? And saved the defined TX 1 profile to slice A etc. And then defined a global SO2R profile? Secondly, on a European keyboard at least one need to find the correct key that produces the right ASCI code? Some keyboards mix them up.0
Kari,
TNX for our response. Does this give you any hint of where to look for problems?
The set up used was from a Flex write up by K9CT for a 6700. My keyboard is standard used in USA.
Hello Dallas,
I followed this guide some years ago and it got me going on N1MM+, worked good....
http://www.flexradio.com/downloads/so2r-mode-with-n1mm-for-the-flex-6700-how-to-guide-pdf/
Thanks to all for the help ... N1MM+ AND SSDR are both working in the SO2R mode. Once the com ports were aligned. Radios are fun but computers are a challenge especially for us older guys ...
Now to train the operator how to use the SO2R system for morer Qs.
de Dallas k1DW2 -
Try the Writelog Contest simulator and you will be prepared. The built in morserunner mode in N1MM only works well in SO1V mode.0
hang in there.. I have N6RO (an octogenarian) working with a 6600-M now. It does get easier. practice makes perfect.0
- 378 Community Topics
- 119 SmartSDR+
- 193 DAX
- 38 Aurora
- 259 FLEX-8000 Signature Series
- 947 Maestro
- 924 Genius Products
