problem getting Winkey working wint N1MM / SSDR
Ed N5DG
I'm new to SSDR / Flex 6600 . I'm having a problem getting Winkey USB to connect with N1MM and SSDR CAT . I've used Winkey /N1MM on a different computer / Radio without issue ! Connect the Winkey USB cable into the computer created (USB Serial Port COM8) In SSDR Cat V2,3.9 I click Add select (Existing) then select Com 8 / winkey and save . This gives me a error Message (Access to the port com8 is denied) I've tried other ports and all are denied . OS is W7 ... Sending a screenshot, I know I'm leaving out needed information , please ask .
Thanks Ed
Thanks Ed
Leave SmartSDR and SmartSDR CAT out of it. It has nothing to do with making WinKey USB work with N1MM. Start N1MM and set up the WinKey as you would were the Flex not involved. Then connect the key line out of the WinKey to either the front-panel key jack (be sure to set the jack for straight key input, not a paddle) or the ACC connector on the back panel. See the hardware reference manual for the proper pins.
I should note that CWX in the Flex offers a WinKey emulator, and this is where you use CAT, to set up a WinKey emulator port, which can also be connected to N1MM. However, from personal experience, I think you will be much happier with the real WinKey.
Craig, KØCF
Craig, Thanks , This gives me a direction to go ... wish me luck
Ed
Yep I use the same old physical com port and it works great.0
Tnx agn Craig , all working a charm . I can send via the paddle or N1MM
Ed0
- 337 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 170 SmartSDR for Maestro and M models
- 401 SmartSDR for Mac
- 264 SmartSDR for iOS
- 247 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 18 Aurora
- 188 FLEX-8000 Signature Series
- 913 Maestro
- 886 Genius Products
- 320 Tuner Genius XL
- 116 Antenna Genius
- 281 Shack Infrastructure
- 197 Networking
- 137 Contesting
- 741 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 954 Third-Party Software
