problem getting Winkey working wint N1MM / SSDR
Ed N5DG
Ed N5DG Member
edited January 2020 in FLEX-6000 Signature Series
I'm new to SSDR / Flex 6600 . I'm having a problem getting Winkey USB to connect with N1MM and SSDR CAT . I've used Winkey /N1MM on a different computer / Radio without issue ! Connect the Winkey USB cable into the computer created (USB Serial Port COM8)  In SSDR Cat V2,3.9 I click Add  select (Existing) then select Com 8 / winkey and save . This gives me a error Message (Access to the port com8 is denied)  I've tried other ports and all are denied . OS is W7 ... Sending a screenshot, I know I'm leaving out needed information , please ask .
Thanks Edimage
  • Craig_KØCF
    Craig_KØCF Member ✭✭✭
    edited July 2018
    Leave SmartSDR and SmartSDR CAT out of it. It has nothing to do with making WinKey USB work with N1MM. Start N1MM and set up the WinKey as you would were the Flex not involved. Then connect the key line out of the WinKey to either the front-panel key jack (be sure to set the jack for straight key input, not a paddle) or the ACC connector on the back panel. See the hardware reference manual for the proper pins.
    I should note that CWX in the Flex offers a WinKey emulator, and this is where  you use CAT, to set up a WinKey emulator port, which can also be connected to N1MM. However, from personal experience, I think you will be much happier with the real WinKey.
    Craig, KØCF
  • Ed N5DG
    Ed N5DG Member
    edited July 2018
    Craig, Thanks , This gives me a direction to go ... wish me luck
    Ed
  • Bill English
    Bill English Member
    edited January 2020
    Yep I use the same old physical com port and it works great.
  • Ed N5DG
    Ed N5DG Member
    edited July 2018
    Tnx agn Craig , all working a charm . I can send via the paddle or N1MM
    Ed
