Flex stop shipping PGXL?
Not good news if it's true !
73 Chris
Think about it ... Why would flex call anyone and tell them they stopped shipping, think about it.0
Tell me, i have no idea. Never heard about any problems. All beta tester praise the Amp. So maybe any other reason ?
Waiting for a comment from Flex. Nothing else matters.0
I would be very surprised by this. I also ordered and was told about December of this year is when to expect it. Also curious if there is anything from flex about this, but I think it is likely not true.0
If the "I received mine" posts are any indication, very few PG-XL's have been shipped so far. I've only seen 3. I can deal with the extended wait time but if there's a problem with the PG-XL it sure would be nice if we got an official update from FRS. If for no other reason, to squelch rumors.
Simple
Demand exceeded Supply - etc
Need to Build another Production Run to take care of Backlog !
Simple as that !
73 Mike
Rumors or fact ?
Fact0
Thank you to all of our loyal FlexRadio customers (Flexers) who have been so patiently waiting for the Power Genius XL (PGXL) amplifiers to arrive.
As you are aware we began shipping the amps in May, and have been slowly rolling out production units after each one completes a rigorous and extensive test/burn in process.
Last month, as more users began exercising the 6-meter (6M) band in the exciting new FT8 mode, units began showing stress in a way not previously experienced. As a result, an issue in the post-amplifier 6M filter was identified. Our engineering team has already identified root cause and incorporated changes into the design to resolve the stress issues with the amp.
Unfortunately, this has further delayed our delivery plan, and at this time we expect to resume shipments in approximately 8 - 10 weeks.
For those individuals who have already received a PGXL we will be rotating each unit through our facility over the the next 6 weeks to address this issue. You will be receiving a more detailed communication in the next few days.
The cost of this process will be completely covered by FlexRadio and the start date of the 2-year warranty period will be reset to the begin when unit is returned following the update, In the meantime, we recommend not running the amp above 500 watts on 6 Meters.
Thank you again to all of the faithful Flexers! If you have any questions or concerns, please don’t hesitate to contact me at matt@flexradio.com any time.
Best regards,
Matt Youngblood
VP Sales and Marketing
5 -
As FRS doesn't release order quantities nor production lot sizes/timing the Supply vs Demand speculation is conjecture.
If FRS really called someone to tell them they stopped shipping a product I am certain they will speak to the community as well. I'm guessing that the actually call, trusting it happened, would be more a timing issue.
When my PGXL was made 4o3a released a picture of that shipment palletized being picked up by UPS. Well UPS Freight had a major snafu with one of their eastern European air freight partners and it didn't get to my station for along time.
I had the same with an SP7IDX Hexbeam that left Poland and apparently went on a horse-drawn wagon to the port and then by **** freighter for the next ninety plus days.
I really like my PGXL and have been getting great reports.
Fortunately the patience we've all had in getting a PGXL for our station is well rewarded with "an amp for the impatient" once on the air!
Again shipments of product is still ramping up and may be subject to ebbs-&-flows, but the product is performing solid in my shack.
Steve K9ZW
Matt,
This is why I am a Flex Radio Person
FRS stands behind their Product !
WB6DJI
WOW . .. another 2 1/2 months.
Steve,
Well, I rather have it done right than not right !
Mine is already 95% Paid with my Deposit & Trade-In
Been 13months wait so far - hope the wait will be worth it !
WB6DJI
Well yes, FRS does stand behind products and this is a good example.
But it is also why I chose to wait on the PGXL and get a tried and true SPE product for now. Certainly not as nice I don't think as the PGXL but I have it now and it's rock solid.
When the PGXL is debugged and sales are caught up I will consider a switch.
Not posting this to sway ANYONE away from PGXL... It is just how I approached the problem.0 -
For those that do not use 6m on FT8 at full power at least this does not apply. As it sits the PGXL is a super high end amp. I don't think there are many amps out there that will run FT8 on 6m at full power all day.1
Same here, patience is not one of my virtues. Just snatched an OM Power 2000+ auto for $4K. It does no time limit full power on all bands, including 6 meters. The best remote capabilities you will ever find in an amp, including remote on/off.0
Simple. Demand exceeded Supply - etcThankfully FRS straightened that fact out! :^))0
This is not what FRS states. How is the output transformer performance on 6 related to demand/supply?0
Exactly.
I was within days of ordering a 2K-FA when FRS started advertising the PG-XL. I like the idea of having control of my Flex and PG-XL via SSDR along with other aspects of the PG-XL so I put my deposit down, and got in line for the wait. Hopefully I made the right decision.
When I fact check, looks like they were not fact's at all, unless stated from Flex.
Lessons learned? I hope.0 -
It may not apply but everyone is affected who ordered one.0
Thank you Matt for the update! I don't mind the extra wait time if the product is perfected. I am glad this was noticed early on and addressed.1
And let's not forget you really should not be running that much high power on FT8 anyway. It is not RTTY. But that is a whole other topic not for this group.0
WRONG FT8 IS A WEAK SIGNAL MODE NOT A LOW POWER MODE You may need to run power to work weak ones. But when running power you need to be careful not to overdrive your signal as that make the reception of your signal worse.3
Nice amp...BUT very expensive..you guys got too much money, can you send me some???????0
Lol, I wonder about amps costing $12.000 or more. Guess that is what high end is all about, weather it's high end cars, high end audio, what ever,,,0
Thank you Matt, and FRS in general for the update and truthful explanation. Am I disappointed? Very mildly. I Have my AL-82 which still works very well for me. I especially wanted the PG XL for 6 meter coverage and its tight software integration with my 6700. I appreciate the forthright answer to what i am sure were complaints from the field and Flex shouldering responsibility. This is why I appreciate Flex and and am a supporter. Sure the process has been long and drawn out. But we are all human. I appreciate the desire to have a top notch product and the factory commitment to support that product. When I had bought my last truck, it's delivery was held up for about 6 weeks because of a possible fire hazard from a seat heater. While I wanted my truck, I was desirous of not having a fire hazard. All was fixed with a factory kit and I had my brand new truck about 6 weeks later. Product support: Its value cannot be overestimated.
Lack of support is why I don't buy a certain brand of car anymore. A known design defect was not covered by an extended a warranty for repairs (60,000 mile power train warranty with defect manifesting at 63,000 miles). Flex has my business locked in and has solidified my opinion by their commitment to very high product quality and commitment to meet their obligations.
Well done, Flex Radio Systems.
Brad
KE4XJ2 -
There is always the age old: build your own...
The BA amp group has a nice solid state amp you can buy a kit for at a fraction the cost of the PGXL:
https://rf-kit.de/en/Products.php
I'll stick with my LA-1K and HF auto for now . . . Thank You
- 361 Community Topics
- 622 The Flea Market
- 8.1K Software
- 48 SmartSDR+
- 6.3K SmartSDR for Windows
- 180 SmartSDR for Maestro and M models
- 417 SmartSDR for Mac
- 269 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 226 FLEX-8000 Signature Series
- 929 Maestro
- 904 Genius Products
- 327 Tuner Genius XL
- 118 Antenna Genius
- 290 Shack Infrastructure
- 204 Networking
- 141 Contesting
- 985 Third-Party Software
