WSJT No RF
Spence
This has been asked so many times, but.... WSJT decodes fine, passes CAT test, DAX is selected in mike profile, level is mid way, (WSJT v1.9.1) DAX control panel shows TX streaming working. Smart SDR v2.3.7 , checked the filter passband, selected DIGU, when WSJT tries to transmit, Flex seems to want to transmit ( RED button and TX ready icon turns red ) but there is no RF output. I'm missing something.
Put your TX gain (on DAX) at maximum and see if that does the trick.
de Roger W6VZV
You don't mention weather you ever had it working and this just started happening or you are just setting it up for the first time..
check these things and also in the past i have had to turn off dax (close the dax control panel and restart it).
Do you have dax selected in the tx pane on the right0
It was a working application at one point. I hadn't used the radio for awhile. When I started it up last week, all the settings had changed. Wrong antenna selected, ( that was weird I've never used ANT2 ) but I got that all sorted out.
Installed SmartSDR 2.3.7 , updated WSJT to v1.9.3 and then discovered WSJT and Flex would not transmit.
Level controls on mike panel and WSJT both at MAX setting. No RF
DAX is selected on the TX panel on the right
DAX is set to channel one
Audio is selected just like above: Input RX 1, Output DAX audio TX
I'm going to scratch my head again.0 -
Windows 10? If so you need to make sure a windows 10 update didn't rename any of your audio devices in device manager, search the forum for this topic and fixes for it.0
I would check in the setup of WSJT-X and make sure the correct DAX is selected. I have had mine mysteriously change once or twice, probably something in Win10. I went in the sounds section of windows and unchecked the boxes that said "allow programs to make changes" or something to that effect. Hasn't happened since. There is a check box on each DAX device. Uncheck them all
I would also look at the transmit DAX in the sound control of Windows and make sure the level wasn't muted or turned down. Right click on your speaker icon and select "sounds"
Good luck
Could there be RF output but you do not have radio set to see Tranmision in the waterfall. You mentioned that TX streaming in the DAX control panel showed that it was transmitting.
Stan0 -
I have a power meter in series with the output. I did notice that in the DAX control panel, when I click TUNE in WSJT, TX button is blue, it says that it is transmitting, but the bar graph is all blue regardless of transmit level setting. So DAX says it is transmitting with an amplitude of zero.0
If recommend shooting a short video so everyone can look at the settings and maybe spot something.0
I have had this same problem several times. I have not experienced since the latest update from FRS. When I experienced it seemed random, it would be working fine and then it would quit. Everything mentioned above was checked and not a problem. Restarting both WSJT and SDR would resolve the problem. I have Window 10, and and all my hardware and software are always kept up to date.
There was a Win 10 update within the past week that hosed my DAX Setup and changed the device names on many of the DAX channels, including DAX Audio TX. I needed to re-select the in and out audio devices in WSJT-X. Sometimes when this happens I need to do more in depth audio surgery on the DAX drivers.....1
I want to thank everyone for their suggestions. I discovered that the problem was that WSJT was trying to transmit just outside of the transmit filter passband. It was that simple.0
Very interesting. I avoid that issue by electing file/settings/radio/split operations/rig. This appears to work very well with the Flex 6400 and roughly centers the tx freq inside the passband.
de Roger W6VZV0
- 657 The Flea Market
- 438 SmartSDR for Mac
- 203 DAX
- 385 SmartSDR API
- 52 Aurora
- 295 FLEX-8000 Signature Series
- 969 Maestro
- 944 Genius Products
- 467 Remote Operation (SmartLink)
- 809 Peripherals & Station Integration
