Flex-6300 1.11 CAT weirdness, can't create VSP and other stuff
Ria
Member ✭✭✭
Helping a friend with his radio. He has a 6300 with 1.11.
The SmartSDR CAT cannot create new CAT ports. I did the repair procedure and I also completely reinstalled SmartSDR CAT. No go.
It does "work" with TCP ports but the CAT responses seem all wrong. For example if you're using WSJT-X on 10.138 MHz, the radio will go to 20.356 or something like that. PTT doesn't work.
He's using Win 7.
What could be the issue here?
He's using Win 7.
When I try to create a new serial port it gives a FlexVSP error.0
Hi Ria Have you tried repairing the flexVSP file? ke2yc Larry0
Ria, take a look at Tim's reply in this post. Perhaps it will help.
https://community.flexradio.com/flexradio/topics/cant-connect-via-cat-after-updating-6500-to-1-11-12
Roy - W5TKZ0 -
Ria I have seen this when there were a lot of hidden ports or abandoned ports. Go to device manager, in the View Menu select Show Hidden Devices and then expand the serial ports section and see if there are hidden comm ports. One easy thing to do is open CAT, right-click on the remove button and select reset. This will purge abandoned ports and resync the definitions with the CAT display. Reboot, then run CAT, go back and see if there are greyed out vsp ports. If so, select them, hit Del then OK. Get rid of them, reboot and see if it will work now.
Thanks. I'll try that.0
I have been following the conversation. Did Neal's advice work?
Brad
KE4XJ0
- 338 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 170 SmartSDR for Maestro and M models
- 401 SmartSDR for Mac
- 264 SmartSDR for iOS
- 247 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 19 Aurora
- 190 FLEX-8000 Signature Series
- 913 Maestro
- 886 Genius Products
- 320 Tuner Genius XL
- 116 Antenna Genius
- 281 Shack Infrastructure
- 197 Networking
- 137 Contesting
- 741 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 954 Third-Party Software
