Spots and +0
Burch - K4QXX
Burch - K4QXX Member ✭✭
edited April 2020 in FLEX-6000 Signature Series
After running SSDR with spots for awhile, I have a bunch of +0 spots on the panadapter.  If I use the clear all spots option, it gets rid of the callsign spots but I am still left with the +0 text all over the panadapter.  The only way to get rid of it is to restart SSDR.
Burch
K4QXX
  • YV5WZ
    YV5WZ Member ✭✭
    edited December 2019
     I got the same bug....
    George
    YV5WZ / PY3ZZZ
  • Bill English
    Bill English Member
    edited January 2020
    Me too
  • Mike Steiner, K7QDX
    edited July 2018
    Me three....  I guess the question is what spotting program are you using..  I'm using Slice Master it seems to me it only happened once I upgrade.
  • Lucas Ford
    Lucas Ford Member
    edited July 2018
    I also see the same bug, even re-installed the software, rebooted, tried everything. It comes back. Other then this the spots seem to work fine, just this little issue...Thank you for adding the spot feature by the way. Very cool! I am using the latest Slice Master 6000.
  • k0eoo
    k0eoo Member ✭✭✭
    edited July 2018
    Guys, I had the same question earlier, according to Don (Mr. Slicemaster) the problem with the +0's falls on Flex's plate...
  • [Deleted User]
    edited April 2020
    Thats weird because Im running Mac Logger DX right now  and the spots show and there is no +0 anywhere. I noticed a +1 and a +2 when runnning Slice Master
  • KF4HR
    KF4HR Member ✭✭
    edited July 2018
    On the SSDR Screen, under Settings -> Spots... -> in the Spot Settings window make sure the Levels slider is set to 10 and your +1, +2, etc will turn into call signs.
    edited July 2018
    that seemed to fix it. thanks...
  • [Deleted User]
    edited April 2020
    Just noticed this on the top of my panadapter. They wont go away unless I  X out of Smart SDR and restart.
    They stay there even when changing band.
  • Tim - W4TME
    edited July 2018
    I have entered this problem report into our bug tracker (issue #6453) for additional investigation. Thank you for the defect report.
  • Lucas - W6AER
    Lucas - W6AER Member ✭✭
    edited November 2018
    It appears the suggestion above fixed this when I move the slider to the right but I suspect this us not how it was intended. Works fine though for now. Thanks!
