Spots and +0
Burch - K4QXX
After running SSDR with spots for awhile, I have a bunch of +0 spots on the panadapter. If I use the clear all spots option, it gets rid of the callsign spots but I am still left with the +0 text all over the panadapter. The only way to get rid of it is to restart SSDR.
Burch
K4QXX
I got the same bug....
George
YV5WZ / PY3ZZZ
Me too0
Me three.... I guess the question is what spotting program are you using.. I'm using Slice Master it seems to me it only happened once I upgrade.0
I also see the same bug, even re-installed the software, rebooted, tried everything. It comes back. Other then this the spots seem to work fine, just this little issue...Thank you for adding the spot feature by the way. Very cool! I am using the latest Slice Master 6000.
Guys, I had the same question earlier, according to Don (Mr. Slicemaster) the problem with the +0's falls on Flex's plate...0
Thats weird because Im running Mac Logger DX right now and the spots show and there is no +0 anywhere. I noticed a +1 and a +2 when runnning Slice Master
-1 -
On the SSDR Screen, under Settings -> Spots... -> in the Spot Settings window make sure the Levels slider is set to 10 and your +1, +2, etc will turn into call signs.
that seemed to fix it. thanks...0
Just noticed this on the top of my panadapter. They wont go away unless I X out of Smart SDR and restart.
They stay there even when changing band.
I have entered this problem report into our bug tracker (issue #6453) for additional investigation. Thank you for the defect report.
It appears the suggestion above fixed this when I move the slider to the right but I suspect this us not how it was intended. Works fine though for now. Thanks!0
- 438 SmartSDR for Mac
- 203 DAX
- 385 SmartSDR API
- 52 Aurora
- 296 FLEX-8000 Signature Series
- 969 Maestro
- 944 Genius Products
- 809 Peripherals & Station Integration
