Turn off/on the DAX TX Stream
Gary L. Robinson
Is there any way to programmatically turn the DAX TX Stream (TX button) off and on?
Radio TX DAX On / Off is on:
FlexAPI Radio object DAXOn property.
TCP command "transmit set dax=<0 or 1>"
To set which slice is TX slice:
Slice object IsTransmitSlice property.
TCP command "slice set <slice index> tx=<0 or 1>"
I just want to turn the DAX TRX Stream on. There doesn't seem to be an easy way to do that. With CAT you can add, delete, whatever. But with DAX it seems to be a lot more complicated. I have a 6400M by the way.
Mark Griffin, KB3Z
- 375 Community Topics
- 104 SmartSDR+
- 425 SmartSDR for Mac
