Turn off/on the DAX TX Stream
Gary L. Robinson
Gary L. Robinson Member ✭✭
edited July 2018 in SmartSDR API
Is there any way to programmatically turn the DAX TX Stream (TX button) off and on?
  • Mark_W3II
    Mark_W3II Member ✭✭✭
    edited July 2018
    Radio TX DAX On / Off is on:
    FlexAPI Radio object DAXOn property.
    TCP command "transmit set dax=<0 or 1>"
    To set which slice is TX slice:
    Slice object IsTransmitSlice property.
    TCP command "slice set <slice index> tx=<0 or 1>"
  • Mark Griffin
    Mark Griffin Member ✭✭✭
    I just want to turn the DAX TRX Stream on. There doesn't seem to be an easy way to do that. With CAT you can add, delete, whatever. But with DAX it seems to be a lot more complicated. I have a 6400M by the way.
    Mark Griffin, KB3Z
