WSJT-X, FLDIGI, F1500 and VAC Audio Issues
DonS
Member ✭✭✭
I have VAC v4.14 running with two cables set set up. In PSDR I am using for VAC1 Driver WDM-KS with Virtual Cable 1 on input and Virtual Cable 2 on output. I can find the VACs in Device Manager, however, they have DAX names with VAC in (). See attached. I tried using the DAX name but had issues regarding which pair or even if it would work. I am running Win 10 using fldigi and wsjt-x which works on on SSDR. Any Thoughts?
Don - kx9q
Don - kx9q
Don
It appears your DAX devices have stomped on your VAC devices, you might need to remove all of the DAX and VAC devices, then reinstall them, maybe installing DAX first then VAC. I've had these issues before. Be sure to select View > Show hidden devices in Device Manager after a reboot to be sure ALL DAX and VAC devices are removed from Device Manager before reinstalling any of them. Windows often gets Virtual Sound device creation wrong, and/or mislabels them. If that doesn't correct the device names try again but reverse the order, trying VAC install first, DAX second.73, Jay - NO5J
I can remove everything except the VAC files. Not sure how to remove the VAC app since I cannot find the app in Apps & features. What am I missing?
Don - kx9q0 -
Don
Let me do some digging through my PC I should be able to figure out where they might be hiding.
Maybe you could drop into the #FlexRadio IRC chat channel while your waiting. I keep PowerSDR and SmartSDR installed on a multibooted Win10-32 bit partition, I'll need to reboot to be able to do the searching.
If you do join the IRC channel, I may miss you joining, due to the rebooting.
So wait around till I rejoin.73, Jay - NO5J
Don,
Windows has renamed the VAC devices. Try renaming the duplicated DAX entries to VAC Line 1 and line 2.
Andrew VK5CV0 -
Hi Russell
How do I go about renaming these entries?
Don - kx9q0 -
I also have what are now ghost entires. See above picture all but the following are greyed out when I do Show hidden devices:
DAX RESERVED IQ RX 1 (Virtual Audio Cable)
DAX RESERVED IQ RX 2 (Virtual Audio Cable)
DELL ST2421L ...
SPEAKERS / Headphones ...0 -
Don
I can show you how to remove those ghosted devices, Find me in the #FlexRadio IRC chat channel when your ready to solve that problem.
Anyone else with Ghosted Devices is welcome to join the IRC discussion.73, Jay - NO5J
I am on the chat channel.
Don - kx9q
I got a response from Eugene - VAC author - and I was able to remove VAC - didn't read far enough in his instruction manual for "uninstallation", however, I still have all these ghost DAX Audio under Audio inputs and outputs. Is there a way to remove these ghosts?
Don - kx9q0 -
Don, This may help. Andrew VK5CV https://helpdesk.flexradio.com/hc/en-us/articles/200883925-Removing-Hidden-or-Ghosted-Com-ports0
I want to thank Jay, Andrew and Eugene (VAC). Removed SSDR and VAC. Reinstalled SSDR and VAC and removed the ghosts and now the F1500 works well with fldigi and WSJT-X.
Don - kx9q0
- 328 Community Topics
- 595 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 397 SmartSDR for Mac
- 260 SmartSDR for iOS
- 247 SmartSDR CAT
- 179 DAX
- 369 SmartSDR API
- 9.1K Radios and Accessories
- 15 Aurora
- 163 FLEX-8000 Signature Series
- 911 Maestro
- 51 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 135 Contesting
- 726 Peripherals & Station Integration
- 136 Amateur Radio Interests
- 945 Third-Party Software
