flex 6300 and JtalertX
edited March 2020 in FLEX-6000 Signature Series
flex 6300; latest software for JtalertX, WJSTx
to use this setup dax audio tx is the default playback device in win10 and specified in output for WJSTx; this is the only way to send transmissions;
Jtalertx will give visual indications of CQ's etc. but there is no audible alert
any ideas to have the audible alerts with dax audio tx as the default?
Thanks Greg K4GAZ
Welcome!
  • Member ✭✭
    edited July 2018
    The alerts are played back through your internal or external PC sound card, Look in JT-ALEART it states not using the same device as your using for WSJTX, you must use either on board sound card or an external sound card for the alert notifications.
  • Administrator, FlexRadio Employee admin
    edited June 2018
    You should NEVER set any DAX audio device as the default or default communication device.  That should be for your local hardware based sound card.
  • Member ✭✭
    edited March 2020
    thanks you mean that dax audio tx should just be listed as the wjstx output and not what the win10 playback suggests?
    Greg
  • Member ✭✭
    edited June 2018
    Here is a link to a previous post on setting up FT8 that helped me get started:
    https://community.flexradio.com/flexradio/topics/ft8-setup-with-flex-6300
    It should apply to any radio running SSDR.
  • Member ✭✭
    edited June 2018
    correct - your windows 10 default sound card- ( what you would use if playing some online or an audio files thru your speakers) is what you need to set the JT-ALERT sound card too, this way when they are displayed in the JT-Alert panel depending on how you have sounds configured for needed area they will be announced through your windows 10 computer and audio device. NOT DAX.
  • Member ✭✭
    edited March 2020
    thanks to all
    I incorrectly assumed that because win10 set up the playback it was correct
    Greg
