No Waterfall when using Smart Link
AE0MW
I'm using the latest SmartSDR for iOS, combined with the newly released (although this problem existed on the prior version as well) of SmartSDR for my Flex 6500.
Everything works, except I get no waterfall display. If I enable the waterfall, I simply get black space. If I disable it the panadapter fills the screen as expected.
I tried deleting and re-installing SmartSDR for iOS, and I also tried using my iPhone (7) as opposed to my iPad Pro (10.6). Both are running iOS 11.4.
I've used SmartSDR for Windows via SmartLink, and the Waterfall does work there, and my setup passes the port forwarding tests built into the SmartSDR SmartLink Setup dialog box. The waterfall works normally on my LAN. It's just over SmartLink that it looses it.
Any ideas?
Thanks!
-Mike
Any ideas?
Thanks!
-Mike
I have SDR_IOS 2.5.1 and ssdr 2.3.7 running fine here on IOS 11.4
AL, K0VM
Yep, I believe you. I searched before I posted and didn't find anyone else with the problem. I'm hoping Marcus will see and offer some enlightenment...
-Mike
- 375 Community Topics
- 104 SmartSDR+
- 425 SmartSDR for Mac
- 999 Third-Party Software
