spot display with ssdr 2.3.7
2»
  • K1DBO
    K1DBO Member ✭✭✭
    edited June 2018
    ...sorry, should have mentioned that there is an email address on the Slice Master splash screen or my address at QRZ works too.
  • W9BS
    W9BS Member
    edited June 2018
    Thank you.  File is on the way.
  • Dave AA6YQ
    Dave AA6YQ Member ✭✭
    edited July 2018
    As Dave NX6D reports above, displaying active callsigns on SmartSDR with Commander 13.6.5 does require that you click the Bandspread button on Commander's Main window, which displays Commander's Bandspread window; after doing so, you can minimize or close Commander's Bandspread window. This defect will be corrected in the next version of Commander.
    I have updated Displaying Active Callsigns on SmartSDR's Panadaptor accordingly.
  • Mark_W3II
    Mark_W3II Member ✭✭✭
    edited June 2018
    FRStack does not have a feature to display telnet SPOTS. FRStack provides a menuing system via SPOT. Use DXLabs, N1MM, SliceMaster etc to get Telnet SPOTS.
  • Andrew Chesnokov
    Andrew Chesnokov Member
    edited June 2018
    Configured SSDR and Commander per Dave's instructions. All spots in SSDR panadaptor shown at extreme bottom of the band though, i.e. 14.000, 7.000 ,3500 etc.
  • Dave AA6YQ
    edited June 2018
    Pick a callsign that is being displayed at the bottom of the band. Now examine SpotCollector's the Spot Database Entry for that callsign. What frequency does this entry specify?
  • Steven WA8Y
    Steven WA8Y Member ✭✭
    edited June 2018
    Well you have to go to the config button on the band spread and you have to click the button for the display
  • Jay Spaulding
    Jay Spaulding Member
    edited June 2018
    Does it work with Log4om? Or can you have it grab spots from the internet with out even having a log that does cluster?
  • Andrew Chesnokov
    edited June 2018
    DB shows freq like 1.41930000000000 or 7.1150000000000 etc
  • Dave AA6YQ
    edited June 2018
    SpotCollector displays frequencies in kilohertz, some something is badly wrong.
  • Andrew Chesnokov
    edited June 2018
    Frequencies in Spotcollector are ok 14.193,0 or 7.115,0
    But in Spotcollector DB weird
  • Dave AA6YQ
    edited June 2018
    Please make a screen shot showing whatever it is that is "weird", attach the screen shot to an email message, and send it to me via aa6yq (at) ambersoft.com
