flex 6300 and JtalertX
Salty Z
flex 6300; latest software for JtalertX, WJSTx
to use this setup dax audio tx is the default playback device in win10 and specified in output for WJSTx; this is the only way to send transmissions;
Jtalertx will give visual indications of CQ's etc. but there is no audible alert
any ideas to have the audible alerts with dax audio tx as the default?
Thanks Greg K4GAZ
Thanks Greg K4GAZ
The alerts are played back through your internal or external PC sound card, Look in JT-ALEART it states not using the same device as your using for WSJTX, you must use either on board sound card or an external sound card for the alert notifications.0
You should NEVER set any DAX audio device as the default or default communication device. That should be for your local hardware based sound card.1
thanks you mean that dax audio tx should just be listed as the wjstx output and not what the win10 playback suggests?
Greg0 -
Here is a link to a previous post on setting up FT8 that helped me get started:
https://community.flexradio.com/flexradio/topics/ft8-setup-with-flex-6300
It should apply to any radio running SSDR.
correct - your windows 10 default sound card- ( what you would use if playing some online or an audio files thru your speakers) is what you need to set the JT-ALERT sound card too, this way when they are displayed in the JT-Alert panel depending on how you have sounds configured for needed area they will be announced through your windows 10 computer and audio device. NOT DAX.0
thanks to all
I incorrectly assumed that because win10 set up the playback it was correct
Greg0
- 657 The Flea Market
- 438 SmartSDR for Mac
- 203 DAX
- 385 SmartSDR API
- 52 Aurora
- 296 FLEX-8000 Signature Series
- 969 Maestro
- 944 Genius Products
- 467 Remote Operation (SmartLink)
- 809 Peripherals & Station Integration
