Error at the start of SliceMaster v0.10.4c
IK6DLK Fabrizio
I got the same error after I read this email. Just firing up everything this morning and out of the blue.
I just got it all working last night before bed. And I wake up to this error.
Jay0 -
You will get that error if you run 2 instances of the program
I rebooted and it works again..0
This error was a port conflict between Slice Master's telnet aggregation server and something (possibly a second instance of Slice Master) else. As of v0.10.5 the error no longer prevents Slice Master startup. Instead, it just disables the telnet aggregation server and logs the error.0
I'm running into a similar issue with v0.10.5. It won't start at first, but keeps trying. After a few minutes, it finally connects. Just started this evening. Started before Windows update, and continuing after the update was installed.
Same issue here. Its stability has somehow gone down from 10.3. I do not know why that is the case, any other apps that talk to the flex connect immediately. I have submitted a issue at the github with the error log... Hope this can be fixed.
I actually have started going back to SDRBridge, but it has its issues too. I kind of liked SliceMaster better, when it worked....
Andy
KU7T0 -
Having same issue here. And I only have one instance running. It is version 10.5 Actually happy to hear I am not the only one. Was having an uh oh moment. Clay N9IO0
A reboot of the radio usually clears this one up. My current development version has a better fix. I was hoping to add some feature to the next release but might have to just settle for a bug fix release instead... and soon.0
- 634 The Flea Market
- 135 SmartSDR+
- 198 DAX
- 42 Aurora
- 956 Maestro
- 299 Shack Infrastructure
- 211 Networking
