Error at the start of SliceMaster v0.10.4c
IK6DLK Fabrizio
edited April 2020 in Third-Party Software
SliceMaster v0.10.4cimage
  • Jay Spaulding
    Jay Spaulding Member
    edited June 2018
    I got the same error after I read this email. Just firing up everything this morning and out of the blue.
    I just got it all working last night before bed. And I wake up to this error.
    Jay
  • [Deleted User]
    edited April 2020
    You will get that error if you run 2 instances of the program
  • Jay Spaulding
    edited June 2018
    I rebooted and it works again..
  • K1DBO
    K1DBO Member ✭✭✭
    edited July 2018
    This error was a port conflict between Slice Master's telnet aggregation server and something (possibly a second instance of Slice Master) else.  As of v0.10.5 the error no longer prevents Slice Master startup.  Instead, it just disables the telnet aggregation server and logs the error.
  • David Okay Patton
    David Okay Patton Member ✭✭
    edited December 2018
    I'm running into a similar issue with v0.10.5.  It won't start at first, but keeps trying. After a few minutes, it finally connects. Just started this evening. Started before Windows update, and continuing after the update was installed.
  • Andy - KU7T
    Andy - KU7T Member ✭✭
    Same issue here. Its stability has somehow gone down from 10.3. I do not know why that is the case, any other apps that talk to the flex connect immediately. I have submitted a issue at the github with the error log... Hope this can be fixed.
    I actually have started going back to SDRBridge, but it has its issues too. I kind of liked SliceMaster better, when it worked....
    Andy
    KU7T
  • Clay N9IO
    Clay N9IO Member ✭✭✭
    edited August 2019
    Having same issue here. And I only have one instance running. It is version 10.5 Actually happy to hear I am not the only one. Was having an uh oh moment. Clay N9IO
  • K1DBO
    K1DBO Member ✭✭✭
    A reboot of the radio usually clears this one up.  My current development version has a better fix.  I was hoping to add some feature to the next release but might have to just settle for a bug fix release instead... and soon.
