spot display with ssdr 2.3.7
...sorry, should have mentioned that there is an email address on the Slice Master splash screen or my address at QRZ works too.0
Thank you. File is on the way.0
As Dave NX6D reports above, displaying active callsigns on SmartSDR with Commander 13.6.5 does require that you click the Bandspread button on Commander's Main window, which displays Commander's Bandspread window; after doing so, you can minimize or close Commander's Bandspread window. This defect will be corrected in the next version of Commander.
I have updated Displaying Active Callsigns on SmartSDR's Panadaptor accordingly.1 -
FRStack does not have a feature to display telnet SPOTS. FRStack provides a menuing system via SPOT. Use DXLabs, N1MM, SliceMaster etc to get Telnet SPOTS.0
Configured SSDR and Commander per Dave's instructions. All spots in SSDR panadaptor shown at extreme bottom of the band though, i.e. 14.000, 7.000 ,3500 etc.0
Pick a callsign that is being displayed at the bottom of the band. Now examine SpotCollector's the Spot Database Entry for that callsign. What frequency does this entry specify?0
Well you have to go to the config button on the band spread and you have to click the button for the display0
Does it work with Log4om? Or can you have it grab spots from the internet with out even having a log that does cluster?0
DB shows freq like 1.41930000000000 or 7.1150000000000 etc0
SpotCollector displays frequencies in kilohertz, some something is badly wrong.0
Frequencies in Spotcollector are ok 14.193,0 or 7.115,0
But in Spotcollector DB weird0 -
Please make a screen shot showing whatever it is that is "weird", attach the screen shot to an email message, and send it to me via aa6yq (at) ambersoft.com
- 634 The Flea Market
- 135 SmartSDR+
- 198 DAX
- 42 Aurora
- 956 Maestro
- 299 Shack Infrastructure
- 211 Networking
