Spot Collector and HRD
Al Reeves
I downloaded ver 2.3.7 and installed all OK. How do I get the new spot collector feature to work with HRD?
Al
W1JHU
Al
W1JHU
Al,
You're mixing your metaphors...
Spot Collector is a component of DXLab's logging suite. It provides a way for users of the DXLabs suite to get spots into the Flex.
HRD, as you know, is a whole other thing. If you would like a tight integration between your Flex and HRD, I'd suggest that Slice Master might just be for you. It will put spots into the Flex and is able to "color" those spots with information from HRD Logbook to show their "needed status".
You can read about Slice Master here:
https://github.com/K1DBO/slice-master-6000
Give it a try... the price is right too.
--Don
Thanks for the tip about Slice Master! I just looked through the Github page and it is fascinating!
-Stan W2VID0
- 384 Community Topics
- 646 The Flea Market
- 149 SmartSDR+
- 262 SmartSDR CAT
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
