Spot Collector and HRD
Al Reeves
Al Reeves Member ✭✭
I downloaded ver 2.3.7 and installed all OK.  How do I get the new spot collector feature to work with HRD?
Al
W1JHU
  • K1DBO
    K1DBO Member ✭✭✭
    edited June 2018
    Al,
    You're mixing your metaphors...
    Spot Collector is a component of DXLab's logging suite.  It provides a way for users of the DXLabs suite to get spots into the Flex.
    HRD, as you know, is a whole other thing.  If you would like a tight integration between your Flex and HRD, I'd suggest that Slice Master might just be for you.  It will put spots into the Flex and is able to "color" those spots with information from HRD Logbook to show their "needed status".
    You can read about Slice Master here:
       https://github.com/K1DBO/slice-master-6000
    Give it a try... the price is right too.
    --Don
  • Stan W2VID
    Stan W2VID Member ✭✭
    edited June 2018
    Thanks for the tip about Slice Master!  I just looked through the Github page and it is fascinating!
    -Stan  W2VID
