Flex helper
Wayne Michael
I wrote a little app that runs on my PC that makes it easier for my **** fingers to control my Flex on the iPad via team viewer.
I don't mind sharing the application
I wrote it for the Flex-6600 but it should work with any SmartSDR radio (I assume).
Its available here:
http://indianaelmernetwork.us/software/
Its available here:
Requires SmartSDR and I have only tested it on the 6600.
Please send feedback to ac9hp@arrl.net
The basic premise is - on the bottom you can configure a list of apps. If those apps are not running then the app name is highlighted in RED. Once running it turns green.
You can control RF Gain and power. (Assumes you run ACG-OFF -if not gain will have no effect I think).
Also added antenna port selector and a LARGE SWR display that shows you if your antenna fell over or also can be used to know your transmitting.
Thanks!
Wayne
AC9HP
Hi Wayne
That is so cool. I have to give this a try.
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
