6500 not turning on following 2 fast shut downs. I changed my station moving equipment to
Jim
Any internal fuses in the 6500?
usually a blown internal fuse would show in the front display of the 6500 as an error.0
Page 23 of the FLEX-6000 Hardware Reference Manual
30 amp internal fuse.
http://www.flexradio.com/downloads/flex-6000-hardware-reference-manual-pdf/
Yes, there is a 30 amp fuse in the 6500 and if it was blown, the radio would do nothing when the power button was pressed.
Fast shut down could be your power supply crowbaring (if it has such a circuit).
Check your power supply first. If it does the same thing with a different p/s, open a HelpDesk ticket.0 -
Will do Tim. The power supply is an Astron SS-25. I have a bench 12 VDC supply.
The fuse was not blown. It does not turn on so I suspect there is damage else where.0 -
If the voltage isnt high enough it will shutdown, check the power pole connections.0
Thanks Larry. The voltage is ok. Also a second power source made no change.
Jim - KD4LN0 -
Another supply did not help. I will ask for a Help Desk Ticket.
Jim - I'll create you a HelpDesk ticket from this post.0
I have requested a ticket. I just mentioned 1 attempt to transmit. The bottom line is simply that it does not turn on.
Thanks again Tim.0
- 653 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
