Transverter
Merle Watts
I am getting errors when using a transverter. Both on smartsdr 2.2.8 and on the maestro. Attached is a pic of the pc screen. Any ideas?
Check to make sure the offset that is specified in mhz is correct. I had it wrong when I was trying to use 10m but it was on the M model standalone so no exception msg it just wouldnt work.0
Can you post your transverter settings?1
found the problem. In memory Channels the step was set at 0.
- 113 SmartSDR+
- 944 Maestro
