6300 old owner seeing the rig
Pat Hamp
Pat Hamp Member ✭✭
edited April 2020 in FLEX-6000 Signature Series
Old owner was still seeing the rig after I registered it under my account. I created a Smartlink account and registered the radio to it, also changed the radio name and call. Have I done everything I should?
  • Neal - K3NC
    Neal - K3NC Inactive Employee ✭✭
    edited June 2018
    Pat
    Are you sure you registered the radio under your account? Go to the radio chooser in Smartlsdr, log into Smartlink if you are not already, then highlight the radio and click on smartlink setup. Does the radio show as registered?
    I would unregister it and re-register it anyway. If it still shows up under the old account, create a helpdesk ticket and we will take a look!
  • [Deleted User]
    edited April 2020
    I'm not seeing it now Pat
  • Pat Hamp
    Pat Hamp Member ✭✭
    edited June 2018
    Cool, I thought I got but wasn't sure. More reading this week and experimenting. Thanks to both of you, climbing the learning curve every day! Because, when you are through learning, you're indeed though.
    Pat
