6300 old owner seeing the rig
Pat Hamp
Old owner was still seeing the rig after I registered it under my account. I created a Smartlink account and registered the radio to it, also changed the radio name and call. Have I done everything I should?
Pat
Are you sure you registered the radio under your account? Go to the radio chooser in Smartlsdr, log into Smartlink if you are not already, then highlight the radio and click on smartlink setup. Does the radio show as registered?
I would unregister it and re-register it anyway. If it still shows up under the old account, create a helpdesk ticket and we will take a look!
I'm not seeing it now Pat
Cool, I thought I got but wasn't sure. More reading this week and experimenting. Thanks to both of you, climbing the learning curve every day! Because, when you are through learning, you're indeed though.
Pat
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 298 FLEX-8000 Signature Series
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
