What is the procedure to calibrate the frequency of a 6600M running 2.2.8?
James Charlton
I discovered that my brand new 6600M is slightly off frequency. Other posts to this site describe the same problem on other flex models and mention a calibration procedure, but none says what the procedure is or where to find it.
I would appreciate it of someone would describe the procedure to tell whee to find it.
Thanks in advance,
Jim Charlton AD0AB
Thanks in advance,
Jim Charlton AD0AB
On the radio screen Press MENU.
On the left side of the screen a list will appear.
Press Radio
Under Frequency Offset Press Start.
The radio will now automatically zero beat to the WWV station selected.
Hope this solves your problem.
73 Tom W3FRG
You have to have antenna connected to antenna 1. Found out the hard way it would not work off of antenna 20
Page 113 of the flex 6400m/6600m manual for smartsdr version 2.1.30 dated 29 January 2018.0
here is the page
Thank you very much! I appreciate the help,
Jim
Good point. I'm totally new to Flex and sometimes don't realize exactly what's happening. Thanks,
Jim
Thanks! I have v 2.2.8 and only looked in that documentation. I'll download the version you reference,
Jim
Thanks again! I guess you know what I'll be doing this weekend!
Jim
- 655 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 969 Maestro
- 940 Genius Products
