What is the procedure to calibrate the frequency of a 6600M running 2.2.8?
James Charlton
James Charlton Member ✭✭
edited January 2020 in FLEX-6000 Signature Series
I discovered that my brand new 6600M is slightly off frequency.  Other posts to this site describe the same problem on other flex models and mention a calibration procedure, but none says what the procedure is or where to find it.
I would appreciate it of someone would describe the procedure to tell whee to find it.
Thanks in advance,
Jim Charlton  AD0AB
  • Tom W3FRG
    Tom W3FRG Member ✭✭
    edited January 2020
    On the radio screen Press MENU.
    On the left side of the screen a list will appear.
    Press Radio
    Under Frequency Offset Press Start.
    The radio will now automatically zero beat to the WWV station selected.
    Hope this solves your problem.
    73 Tom W3FRG
  • Lawrence Kellar KB5ZZB
    Lawrence Kellar KB5ZZB Member ✭✭
    edited January 2020
    You have to have antenna connected to antenna 1. Found out the hard way it would not work off of antenna 2
  • Wayne
    Wayne Member ✭✭
    edited January 2020
    Page 113 of the flex 6400m/6600m manual for smartsdr version 2.1.30 dated 29 January 2018.
  • Wayne
    Wayne Member ✭✭
    edited June 2018
    here is the page image
  • James Charlton
    edited June 2018
    Thank you very much! I appreciate the help,
    Jim
  • James Charlton
    edited June 2018
    Good point.  I'm totally new to Flex and sometimes don't realize exactly what's happening.  Thanks,
    Jim
  • James Charlton
    edited June 2018
    Thanks!  I have v 2.2.8 and only looked in that documentation.   I'll download the version you reference,
    Thanks,
    Jim
  • James Charlton
    edited January 2020
    Thanks again!  I guess you know what I'll be doing this weekend!
    Jim
