Used Maestro with problems
Carl N8VZ
In wich way are the Maestro connected, as well as your radio, to your local network? Hardwired to the radio? To a router/switch or wireless. I think we need to know a bit more about this to be able to suggest what could be the problem. By the way, what radio are you using?0
Do a direct connect to the radio then hold the power button down and hold it till it shuts down. I have had that happen to mine on a few occasions. That is how I corrected it.1
It is a wireless connection. The radio is a 6500. 73 de Carl N8VZ0
I will try the direct connection and report back. Thanks. 73 de Carl N8VZ0
Gl Carl!
I think Steve are right on it and I think you might solve the problem with the direct connection. I have had similar problem just a few times, always when on my Wireless net and then connecting to the Lan with cable and restarting has always solved it.
I have a wireless lan with several accesspoints to give very good coverage even outside in the garden. But Maestro and Wireless is not always good pals, never had a problem when on wired Lan.1 -
Thanks for your feedback Johan and Steve. The direct connection did help; however, I still am not "out of the woods" yet. It will now boot to the screen where it IDs the radio and I connected to it. When I clicked on "Connect" it goes to the screen where you can choose the software version. I selected the most recent v2.2.8. It then went through the routine of reinstalling it. After that I got the message "Waiting on Hardware Initialization." At first, there were several letters showing: W, X, Y, Z, K, YTS, ETH. Then, it displayed only "Waiting on Hardware Initialization (ETH)." At that point, it is apparently frozen, as it has now been ten minutes with no further action. I'm suspecting that I may have had a bad download of the v2.2.8 update. This was installed by me after buying the Maestro. The previous owner had v2.1.33 as the last installed version. Is there a way to force a clean download of that version over again?
P.S. Now, I'm not sure that my diagnosis above is correct. I just tried to reinstall the old v2.1.33 version and got hung up at the same spot: "Waiting on Hardware Initialization (ETH)." I have no idea what to try next. Ideas?0 -
Update:
I now reinstalled v2.2.8 and restarted. First, I got a message saying "An error occurred that requires a restart of the Maestro"
Then when it restarted, I got this error message:
"Error communicating with Maestro Hardware (152). Please try again. (W,X,Y,Z,K)"
Then a Windows dialogue box pops up saying: "A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available." The only option is then to "close the program." Upon doing that the Maestro shuts off.0 -
Hmm . . . I just rebooted it with the Maestro connected directly to the 6500, not through the LAN, and it booted up properly directly to the main screen. Not sure if it's now fixed or if it will continue to be problematic when I try LAN or WiFi boot. 73 de Carl N8VZ
Well, I just turned it off and booted directly to a WiFi connection and right into main screen showing both of my previous slices. Seems to be working. I'm going to put it through a little more of a workout before I pronounce it totally cured.
Check the power supply. Or if you were trying to run from battery use the AC power adapter instead. Ethernet needs more current than WiFi. What you describe sounds like the Maestro was trying to run from the internal battery (which it can't). The internal battery is used to keep it operating while switching battery packs.
If you are using a battery pack and not the AC adapter, make sure the battery pack is a self starting pack otherwise you need to push a button on the pack to turn it on.
I find it is far more prudent and wise to buy new and enjoy the manufacturerer's support and warranty. Buying used for the apparent 'savings' yields false economy and the cause of buyer's remorse.0
Dave: Yesterday I was at first using the battery in the battery compartment which I installed. I then switched to my main ham shack power supply and had the same problems. I only got joy when I connected the Maestro ethernet connection directly to 6500 as suggested by Steve and confirmed by Johan. Now, I can use either the power supply or an external LiFEPO2 battery. The battery in the battery compartment is one of the models that Tim W4TME recommended (Polanfo M50000 Portable Power Bank 12000mAh), but it still is causing problems. It may have been the root of my initial problem, but simply using another source of power did not fix the problem until I did the direct ethernet connection to the rig. 73 de Carl N8VZ
P.S. I just checked my Polanfo battery. Even though I ordered the Polanfo M50000, I see that I actually received the Z-Power, which is rated at 20000MAh, seemingly a better spec. It has both a 1amp and a 2.1amp output. I've been using the latter.
P.P.S. I looks like mine is not a self-starting pack.0 -
I have now discovered that I can actually use the Z-power battery, but I have to first open the battery door and press start. I didn't realize this yesterday, so when I thought I was using the Z-power, I was actually using the internal battery, until I plugged in external power, but at that point some other aspect of the boot up was **** up, so I had to use the direct ethernet connection routine to get it back in the swing. If anyone has a suggestion of a good self-starting pack, please let me know.
I got a pre-owned Maestro as well, and had a similar problem. Mine was self-induced however, because I plugged the power supply in, it came on, and not knowing any better, I held the power button to force it off. At the time I didn't realize a single press the correct way {unless you have to force it off for some reason). It seems the single press puts the tablet in the Maestro into sleep mode, while the long press is a forced shutdown.
It took another restart for me as well; probably had to clean up the stray temp files/minor file corruption caused by the forced power-off.
Just discovered that my Z-power will turn itself off automatically if the current draw is not enough. So, this pack won't turn on automatically but will turn itself off automatically. Maybe I should use the 1 amp output, because apparently the Maestro doesn't draw enough to satisfy it on the 2.1 outlet. I think a different battery pack might be the best solution, however. Suggestions welcome! 73 de Carl N8VZ0
Should have just bought an ipad 6 and the ios app you would have saved a bunch of bucks also :-)1
Wayne, I actually have that app on both my iPhone and iPad; however, I think the Maestro will be easier for backyard use, given my operating style. I use the iOS app more for on-the-road use. 73 de Carl N8VZ0
Well, I plugged the Maestro into the Z-power 1 amp slot, and it's been running FB for about an hour. Apparently, as I said before, the Maestro draws so little power that it goes below a cutoff value and the battery automatically shuts down. But, in the 1 amp slot, it draws enough to keep the battery operating. This is one strange battery, IMHO. I do want to replace it with something that will auto start upon turning on the Maestro. But, for now, I know how to work this little puppy. 73 de Carl N8VZ0
Great to hear you are on the right track Carl
Enjoy the Maestro. I have one and I like it, but like using the PC and Flexcontrol better. But with summer and more opportunities to sit outside working, I'm probably gonna use the Maestro a lot more. 1 -
Thanks for your help, Johan. I'm curious, what is your callsign? I believe you are from Sweden. Is that correct? I'm half Icelandic, as you might have guessed from my middle name. 73 de Carl N8VZ0
The knobs should work well for that then.0
Hi Carl, aha you are of Icelandic origin, I did wonder a bit about your first name. My father, not Icelandic but Swedish, had the same name and spelling. My vanity call, as is my signature here on the community, are SE3X. You will find me on QRZ.com. SE3X is my call for Contest and DX and page is written in English. My personal call is SA3BYC, on QRZ as well, but in Swedish, if you like a language practice session.
- 110 SmartSDR+
- 257 SmartSDR CAT
- 943 Maestro
