6600M external Speaker is not working
Wolfgang
Hi All
I'm not able to use an external Speaker e.g. ICOM SP-34 with my FLEX 6600M. I tried all the plugs at the back - but no sound. I tried with mono and stereo 3.5mm plugs.
Any ideas?
Is this a Hardware or Software Issue?
Wolfgang
You must use speakers with a built in amplifier. I use a visio sound bar with remote control mounted on wall.0
Yes, you need an amplified and stereo speaker connected to all SDRs that Flexradio has produced.0
I use this 12V powered amplifier with my bookshelf speakers
https://www.amazon.com/Lepy-Amplifiers-Component-LP-2020A-Class-D/dp/B01FZKA28Y/ref=sr_1_6?ie=UTF8&a...
Hi TimI just installed a small nice speaker amplifier. But no sound - nothing! I connected the PWR-SPKR output to the input of the amplifier and the output of the amplifier to the input of teh ICOM speaker.
Do I have to enable the PWR-SPKR in the software somewhere?73Wolfgang
There are no controls to turn on or off the powered speaker output, but you can mute it.
I would simplify the problem. Do you have a pair of computer speakers? Connect them to the radio and verify that it is working in that configuration before using a more complex configuration.0 -
Everything is ok now. I just plugged in an old powered Logotech PC speaker - and it works. Issue is solved :-)The nice looking amplifier is not working and ent into the china-trash.
73Wolfgang
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
