MON on FLEX 6600
James Kennedy-WU5E
Member ✭✭✭
Using the MON on the FLEX 6600 it's seams very touchy between not hearing it or it mess up the audio. Any help out there , if had the same issue and how did you fix it?
Jim, WU5E
James, are you trying to set up the EQ? If so you don't want to do it that way. Set power to zero and record yourself and plat it back to see how you sound.
I watched the you tube video on setting the eq up using full duplex using the xvtr port and thats how I set mine up and it worked great for me.0
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
