Can FlexControl be programmed to automatically mute the audio on the prior slices? TNX.
Dave - W6OVP
Can FlexControl be programmed to automatically mute the audio on the prior slice? TNX.
It can be programmed to control volume for sure. Go into settings in the menu bar and pick Flex control and pick volume from list. Mute maybe one I don’t know but volume definitely and spin know to reduce quickly Mike NN9DD0
You can use FRstacks, it will mute inactive slices so you can hear the one your working on.0
Thanks, Bill. I'll take a look at it.
NEXT: Is there a way to automatically switch TX ON to the active slice? (It's too easy to forget and transmit on the wrong slice...)
73 Dave
Frstack does that also0
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 298 FLEX-8000 Signature Series
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
